LM app in android - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: OLD visualization (https://forum.logicmachine.net/forumdisplay.php?fid=9) +--- Thread: LM app in android (/showthread.php?tid=3222) |
LM app in android - DGrandes - 12.03.2021 Hi, I have a question about app. I have a subdomain (lm.mydomain.com) redirected to my lan LM. https://lm.mydomain.com --> http://192.168.1.200 (LM internal IP) It works perfectly i I do that in a web browser and I have protected by SSL but if I put this domain in app, it doesn´t work. Any idea?? Thanks RE: LM app in android - Daniel - 12.03.2021 As far I remember the local device use only http. Try remote, set custom and put it there. RE: LM app in android - DGrandes - 12.03.2021 Local device allow https, but aniway I redirect by inverse proxy, from external https to internal http. With cusom remote it works RE: LM app in android - Daniel - 12.03.2021 You didn't get it. Android app when local(Home) connection is used it use only HTTP. The Remote use only HTTPS try putting any page which has valid SSL cert it will open. RE: LM app in android - DGrandes - 12.03.2021 (12.03.2021, 17:26)Daniel. Wrote: You didn't get it. Android app when local(Home) connection is used it use only HTTP. The Remote use only HTTPS try putting any page which has valid SSL cert it will open. Ok, i understand it. But with remote i only can add one address, and I can´t open it automaticaly when I open app. RE: LM app in android - Daniel - 12.03.2021 Remote will open automatically when your mobile will be on data. Sorry the app was designed for mosaic in mind. |
