Alexa command - Printable Version
+--- Thread: Alexa command (/showthread.php?tid=3268)
Alexa command - Frank68 - 31.03.2021
Hello
I'm trying to configure Alexa, and with regards to on / off lights and dimmers no problem, even for roller shutters and temperature reading.
If, on the other hand, I wanted to read a relative humidity percentage, how should I set it since if I put a percentage it does not recognize them.
RE: Alexa command - Daniel - 31.03.2021
As for the voice response, she can only answer to door lock and temperature. You would need to convert it to 2byte and ask for humidity temperature Smile. Alexa is a simple switch not a messenger.
