Different visualization same user - Printable Version
+--- Thread: Different visualization same user (/showthread.php?tid=3271)
Different visualization same user - Kilogica - 31.03.2021
is it possible in a Wiser for KNX to visualize two different pages one for smartphone visualization and the other for normal visualization?
For example:
I have two different pages, I want the same user to visualize the first in smartphone and the other one on a PC.
Thank you for your help.
RE: Different visualization same user - admin - 31.03.2021
In Vis. structure you can configure whether plan is visible in each visualization mode.
RE: Different visualization same user - Daniel - 31.03.2021
Smartphone visu is equivalent of a custom visu only build automatically. User permission is only for one as both are the same. In Vis structure you can specify if a page is visible or not in smartphone(touch in LM) or custom visu. This way you can make it work.
RE: Different visualization same user - Kilogica - 31.03.2021
Thank you!
