Script change object range values - Printable Version
+--- Thread: Script change object range values (/showthread.php?tid=3289)
Script change object range values - idhe - 07.04.2021
I would like to dynamically change the min and max values of objects (Visualization parameters), how can I do this with a script ? I need to change a temperature range if we are using cooling or heating mode (cooling min 23°C, max 28°C / heating min 15°C, max 25°C), can I modify a group of objects by using tags ?
Thanks,
idhe
RE: Script change object range values - davidchispas - 07.04.2021
(07.04.2021, 08:17)idhe Wrote: Hi,
Thanks,
idhe
I don't know if that parameter can be modified by code ... I did it with a script per event with a 1-byte object. In visu assign a button to increase and another to decrease. This script can be assigned more thermostats by assigning it different values to execute the event. So I would only use a script
--Cool(1)/heat(0) mode status object Mode = '3/1/1' --Setpoint temperature object Temp = '3/1/2' --Setpoint temperature status object Sttemp = '3/1/3' --Cold minimum value ColdMin = 23 --Cold maximum value ColdMax = 28 --Heat minimum value HeatMin = 15 --Heat maximum value HeatMax = 25 ---------------------------------------------------------- value = event.getvalue() if grp.getvalue(Mode) then   Min = ColdMin   Max = ColdMax   else   Min = HeatMin   Max = HeatMax   end   if value == 1 and grp.getvalue(Sttemp)>Min then grp.write(Temp, grp.getvalue(Sttemp) - 0.5)   elseif     value == 2 and grp.getvalue(Sttemp)<Max then grp.write(Temp, grp.getvalue(Sttemp) + 0.5) end
RE: Script change object range values - admin - 07.04.2021
The script solution is more robust. While it's possible to change min/max values via DB queries you will still have to reload visualization for changes to take effect.
RE: Script change object range values - idhe - 07.04.2021
(07.04.2021, 15:19)admin Wrote: The script solution is more robust. While it's possible to change min/max values via DB queries you will still have to reload visualization for changes to take effect.
Thanks, have you an example ? It's not a problem if I have to reload visualization for changes to take effect.
RE: Script change object range values - idhe - 13.04.2021
Ok thanks admin, I found the solution in the lua doc : https://openrb.com/docs/lua.htm#grp.create
RE: Script change object range values - savaskorkmaz - 02.11.2021
(13.04.2021, 13:59)idhe Wrote: Ok thanks admin, I found the solution in the lua doc : https://openrb.com/docs/lua.htm#grp.create
Can you share the solution please ?
I need that also.
Regards
RE: Script change object range values - admin - 02.11.2021
See this: https://forum.logicmachine.net/showthread.php?tid=2374
