Email Backup file stops - Printable Version
+--- Thread: Email Backup file stops (/showthread.php?tid=3291)
Email Backup file stops - Tokatubs - 07.04.2021
I use this script below on an LM5.
When i start the script the email is received. And everything is working fine. But after it runs the active goes of, and shows as red. So next month no backup is sent.
Activating the script again an email is sent.
Any idea why the script stops, or what to try?
--***************************************************************-- --*** For FW spaceLYnk 1.2.1 and FW homeLYnk 1.5.1 or higher ****-- --***************************************************************-- --** Email backup as attachment created by Erwin van der Zwart **-- --***************************************************************-- --********************* Start of parameters *********************-- --***************************************************************-- --Gmail (smtp) username !IMPORTANT! user = 'YOUR GMAIL ADDRESS' --Gmail (smtp) password !IMPORTANT! password = 'YOURPASSWORD' --Sender for e-mail from = '<me@whoismailingyou.com>' alias_from = 'From me' --Recipient for e-mail to = '<someone@youwanttomail.com>' alias_to = 'To you' --Subject for e-mail subjectpart1 = 'Back-up file' subjectpart2 = 'automaticly send by homeLYnk' --Message on bottom of email (will only be showed when client don't understand attachment) epilogue = 'End of message' --***********************************************************-- --******************** End of parameters ********************-- --***********************************************************-- --********** DON'T CHANGE ANYTHING UNDER THIS LINE **********-- --***********************************************************-- --Create table to include mail settings local settings = {    from = from,    rcpt = to,    user = user,    password = password,    server = 'smtp.gmail.com',    port = 465,    secure = 'sslv23', } --Create attachment src = 'backup-' .. os.date('%Y.%m.%d') .. '.tar.gz' dst = '/home/ftp/' .. src -- prepare files for backup os.execute('sh /lib/genohm-scada/web/general/backup.sh') -- create cleanup archive os.execute('cd /lib/genohm-scada/storage && tar -c -z -f ' .. dst .. ' ./') --Create subject subject = subjectpart1 .. ": " .. src .. " " .. subjectpart2 --Load required modules to send email with attachment local smtp = require("socket.smtp") local mime = require("mime") local ltn12 = require("ltn12") --Create e-mail header settings.source = smtp.message{ headers = {          from = '' .. alias_from .. ' ' .. from .. '',          to = '' .. alias_to .. ' ' .. to .. '',          subject = subject }, --Load attachment inside body     body = { preamble = "", [1] = {        headers = {         ["content-type"] = 'application/x-7z-compressed',         ["content-disposition"] = 'attachment; filename="'..src..'"',         ["content-description"] = '.. src ..',         ["content-transfer-encoding"] = "BASE64",      },                    body = ltn12.source.chain(      ltn12.source.file(io.open(dst, "rb")),      ltn12.filter.chain(      mime.encode("base64"),      mime.wrap()        )      )    },      epilogue = epilogue  } } --Send the email r, e = smtp.send(settings) --Create alert when sending gives an error with error message if (e) then  log (e)  log (r)  alert("Could not send email: ", e, "\n") end log("Send Mail") --Delete created backup file from tmp folder inside HL os.execute('cd /lib/genohm-scada/storage && rm -rf user userlib.luas blockly.luas initscript.lua helpers.js genohm-scada.config filter*') -- Disable script automaticly script.disable(_SCRIPTNAME)
RE: Email Backup file stops - admin - 07.04.2021
Remove the last script line
RE: Email Backup file stops - Tokatubs - 07.04.2021
Wow that was quick..
RE: Email Backup file stops - Krstfr2k - 11.06.2021
I have tried implementing this script but I get this error message:
testmail 11.06.2021 13:55:40
* string: 552-5.7.0 This message was blocked because its content presents a potential
552-5.7.0 security issue. Please visit
552-5.7.0 https://support.google.com/mail/?p=BlockedMessage to review our
552 5.7.0 message content and attachment content guidelines. r15sm572457lfr.245 - gsmtp
Any idea on how to resolve this?
RE: Email Backup file stops - admin - 11.06.2021
Use another email provider, not Gmail. The backup has custom JavaScript included which Gmail thinks is harmful and blocks it.
