Wake on LAN - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Wake on LAN (/showthread.php?tid=33) |
Wake on LAN - George - 12.07.2015 Please improve where possible. Function : Wakes up a PC from the Logic Machine Goal : Save power by starting PC's only when needed Requirements : 1. PC must support Wake on LAN. You can verify this in the Bios or by sending a WoL-Packet (Magic Packet) from a Windows or Linux tool. 2. WoL must be enabled Actions : 1. Send Magic Packet 2. Wait a number of seconds 3. Check if portnumber on PC is available 4. If not, log error condition To do : 1. return actionable error code Installation : 1. Add the the code underneath to the function library 2. Create a script with the following line : Wol('aa:bb...:ff', '10.1.x.y', '60', '80') Aa:bb...:ff MAC-address 10.1.x.y IP address (to verify the fail/success state) '60' number of seconds before checking if the required port number is running '80' port number to verify Code Code: function wol(mac, ip, timeout, port)
-- helper function definitions
function wol_send(mac_dest)
local broadcast_ip = "255.255.255.255"
local port = 9
local udp = assert(socket.udp())
udp:setoption('broadcast', true)
local mac_array = string.split(mac_dest, ":")
local mac = ""
for i,v in ipairs(mac_array) do mac = mac..string.char(tonumber(v, 16)); end
local mac1 = ""
for i = 1,16 do
mac1 = mac1..mac
local mac2 = string.rep(string.char(0xff),6)..string.rep(mac, 16)
assert(udp:sendto(mac2, broadcast_ip, port))
-- tries to open TCP connecton to specified IP:port
function tcp_knock(ip, port)
local tcp = assert(socket.tcp())
tcp:settimeout(10)
local success = tcp:connect(ip, port)
Log("tcp knock to " .. ip .. " is " .. (success and "success" or "fail"))
return success
assert(type(mac) == 'string', "mac address (string) should be specified");
assert(type(ip) == 'string', "ip address (string) should be specified");
wol_send(mac)
timeout = tonumber(timeout) or 0
if (timeout > 0) then
print("Sleeping " .. timeout .. " seconds")
os.sleep(timeout)
local knock_success = tcp_knock(ip, port)
if ( not knock_success ) then
local subject = "
local alertmessage = "Wake Up fail: " .. ip .. "/" .. mac
end |
