Mosaic and schedules - Printable Version
+--- Thread: Mosaic and schedules (/showthread.php?tid=3312)
Mosaic and schedules - Alexander - 23.04.2021
Is it possible to use Mosaic to activate and deactivate a schedule in LM?
RE: Mosaic and schedules - Daniel - 23.04.2021
Each schedule has Scheduler on/off object: You can use it anywhere also in Mosaic.
RE: Mosaic and schedules - Alexander - 23.04.2021
(23.04.2021, 12:13)Daniel. Wrote: Each schedule has Scheduler on/off object: You can use it anywhere also in Mosaic.
Hi, do I create an new object (virtual) in LM then?
It is up to you if it is virtual or normal.
(23.04.2021, 16:44)Daniel. Wrote: It is up to you if it is virtual or normal.
Ok, last thing.
So what is the different between virtual and normal?
RE: Mosaic and schedules - Daniel - 24.04.2021
Virtual will not be sent to KNX.
RE: Mosaic and schedules - davidchispas - 26.04.2021
mosaic frame
Hello, will it be possible to view the frames with access from the cloud? I have a framework created to see the programmers, it can be seen locally but not remotely.
RE: Mosaic and schedules - Daniel - 26.04.2021
Frame just point to a url. If url is not accessible from cloud then it will not be visible.
(26.04.2021, 08:44)Daniel. Wrote: Frame just point to a url. If url is not accessible from cloud then it will not be visible.
In local and ddns connection with the address '' / scada-vis / schedulers? Id = 1 '' it is enough to display it.
But remotely through the CLOUD, I have tried the ddns address type:
'' http://example.ddns.net:80/scada-vis/schedulers?id=1 ''
'' http://user:pass@example.ddns.net:80/scada-vis/schedulers?id=1 ''
and I can't visualize it, the frame comes out completely blank. When it rejects the connection it always shows some kind of error.
Am I doing something wrong or is this not going to be possible ...?
You would also need to add credential in your url. This what you do is not the best/secure solution. Why don't you use ZeroTier for remote access to do such modification and cloud mosaic just as remote control?
