User and password on ip cam - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: General (https://forum.logicmachine.net/forumdisplay.php?fid=2) +--- Thread: User and password on ip cam (/showthread.php?tid=3335) |
User and password on ip cam - CristianAgata - 01.05.2021 hello everyone, I'm trying to view Hikvision IP cams with Mosaic (beta). But I can't pass username and password. Anyone have a solution? The formula http://user: password@ip/aspi/.... is rejected by browsers. thanks in advance to who want help me. BR Cristian RE: User and password on ip cam - admin - 03.05.2021 Browsers do not allow URLs in user:pass@host format anymore for security reasons. Some cameras support passing user/pass as a URL query string parameters. If it still does not work then the only option is to disable authentication completely. See this for possible URL formats: https://forum.logicmachine.net/showthread.php?tid=1073 https://www.ispyconnect.com/camera/hikvision RE: User and password on ip cam - CristianAgata - 03.05.2021 (03.05.2021, 06:53)admin Wrote: Browsers do not allow URLs in user:pass@host format anymore for security reasons. Some cameras support passing user/pass as a URL query string parameters. If it still does not work then the only option is to disable authentication completely. Thanks I will see RE: User and password on ip cam - tigi - 03.05.2021 Hi, I had a similar problem with a Hikvision camera. I was unable to have it show in a stable way, not in mosaic, not in homeassistant, etc...). Spend quite some time on it. Didn't have that problem with Axis camera, so I assume it's a Hikvision thing. I solved it by using ispy v7.2 which I had already running on my server. ispy can also produce streaming url's. Camera 1 url is for example: http://10.0.0.15:8081/mjpegfeed?oid=1&size=300x410 Camera 2 url is for example: http://10.0.0.15:8081/mjpegfeed?oid=2 This works perfect, seamless and without headaches. Downside you have to run a server 24/7, but if you already have one running this is the easiest way. Note: ispy is replaced by ispy agent, don't know if it's still possible with that but you can still download ispy |
