Sync error with remote cloud - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: General (https://forum.logicmachine.net/forumdisplay.php?fid=2) +--- Thread: Sync error with remote cloud (/showthread.php?tid=3344) |
Sync error with remote cloud - CristianAgata - 05.05.2021 Hi everybody, I have a problem when I try to sync with the server (new remote cloud) with the old all works fine. In the attached file you can see the capture. Anyway the error is code 135. Best regards Cristian RE: Sync error with remote cloud - Daniel - 05.05.2021 Did you try recently? We were doing some changes. RE: Sync error with remote cloud - CristianAgata - 05.05.2021 (05.05.2021, 15:33)Daniel. Wrote: Did you try recently? We were doing some changes. I made 5 minutes ago RE: Sync error with remote cloud - Daniel - 05.05.2021 There will be new app update Install this and try again https://dl.openrb.com/pkg/lmcloud-20210503.ipk RE: Sync error with remote cloud - CristianAgata - 05.05.2021 (05.05.2021, 15:36)Daniel. Wrote: There will be new app update Next days when I'll came back I will try again and I let you know. Thanks RE: Sync error with remote cloud - CristianAgata - 08.05.2021 Ok, with update it works. Thanks May I ask you if the new remote cloud has some issues on Ios app for mobile? RE: Sync error with remote cloud - Fahd - 27.11.2024 Hi, I do have the same error here RE: Sync error with remote cloud - admin - 27.11.2024 Are you running the latest firmware and LM Cloud app? Post logs from the LM Cloud app. RE: Sync error with remote cloud - Fahd - 27.11.2024 (27.11.2024, 08:49)admin Wrote: Are you running the latest firmware and LM Cloud app? Post logs from the LM Cloud app. Version: 20241003 RE: Sync error with remote cloud - admin - 27.11.2024 If you have single LM - go to https://remote.logicmachine.net/settings, click Actions > Create new connection string then set this connection string in the LM Cloud app. If you have multiple LMs connecting to the same network then any additional LM must be authorized in Actions > Authorize additional LM by ID. LM ID is shown in the bottom left corner of the LM Cloud app. RE: Sync error with remote cloud - Fahd - 27.11.2024 I do have 3 LM on the same network, two of them have their own cloud network and they work fine. this is the 3rd one RE: Sync error with remote cloud - admin - 27.11.2024 It's possible to connect multiple LMs to the same cloud network but only the first is authorized automatically, additional LMs must be authorized manually. If you want to use separate cloud networks per each LM then either reset the connection string or create a new network for LM that cannot connect. RE: Sync error with remote cloud - Fahd - 27.11.2024 Recreate the cloud network; it fixed the problem. Thanks. RE: Sync error with remote cloud - jurmaster - 09.12.2024 I was facing same issue and for me it was good moment to switch to other emailaddress. However when registering a new email address I get no further then the Privacy Policy Terms. Getting a empty browser with: Please support :-) RE: Sync error with remote cloud - admin - 10.12.2024 Try again now, it should be working. RE: Sync error with remote cloud - jurmaster - 12.12.2024 Yes!! Thx works again. |
