Store and modify a data table via script in Wiser for KNX - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Store and modify a data table via script in Wiser for KNX (/showthread.php?tid=3346) |
Store and modify a data table via script in Wiser for KNX - Kilogica - 06.05.2021 Hello, I'm trying to make in W4K a simple booking interface that saves name, code for room unlocking, date of code activation and date of code expiration, is it possible to manage a simple database? I've even thought about JSON but I don't know if it can be safe enough. Any ideas? Thank you RE: Store and modify a data table via script in Wiser for KNX - admin - 06.05.2021 You can create custom tables in LM SQLite database if needed. Docs on LM database commands: https://openrb.com/docs/db.htm RE: Store and modify a data table via script in Wiser for KNX - Kilogica - 07.05.2021 Thank you, I'll check it out! RE: Store and modify a data table via script in Wiser for KNX - Kilogica - 13.05.2021 Hello, is there a way to check database tables besides LUA scripts? RE: Store and modify a data table via script in Wiser for KNX - admin - 13.05.2021 You can download the backup, extract it and view the database using SQLite DB browser or similar software. |
