email? - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: email? (/showthread.php?tid=3352) |
email? - Fred - 08.05.2021 I am using the standard script to send email. LM5 v20191015. No matter what host I set in server, I get an error about "string: 535-5.7.8 Username and Password not accepted. Learn more at 535 5.7.8 https://support.google.com/mail/?p=BadCredentials c5sm15367699wrs.73 - gsmtp" Why on earth would GOOGLE be there if I ask it to go to "sss" ??? How can I debug this? I have tried all the combination of 'secure' found on the forum in various posts over the years; this is really confusing but in any case does not change anything since GOOGLE is always back as error. Thanks for any help or pointers function mail(to, subject, message) -- make sure these settings are correct local settings = { -- "from" field, only e-mail must be specified here from = '...', -- smtp username user = '...', -- smtp password password = '...', -- smtp server server = 'sss', -- smtp server port port = 465, secure = 'tlsv12', -- use STARTTLS mode --starttls = true, } local smtp = require('socket.smtp') if type(to) ~= 'table' then to = { to } end for index, email in ipairs(to) do to[ index ] = '<' .. tostring(email) .. '>' end -- message headers and body settings.source = smtp.message({ headers = { to = table.concat(to, ', '), subject = subject, ['Content-type'] = 'text/html; charset=utf-8', }, body = message }) -- fixup from field settings.from = '<' .. tostring(settings.from) .. '>' settings.rcpt = to return smtp.send(settings) end RE: email? - Erwin van der Zwart - 09.05.2021 Hi, Couple of things to check: 1) Make sure DNS and DG are set correct in the interface settings (otherwise you have no internet access) 2) Enable https://myaccount.google.com/lesssecureapps on your gmail account (otherwise mail from machines is blocked by google) 3) Use these settings in the common functions: Code: -- send an e-mail
local settings = {
from = 'yourmail@gmail.com',
-- smtp username
user = 'yourmail@gmail.com',
-- smtp password
password = 'yoursecretpassword',
-- smtp server
server = 'smtp.gmail.com',
-- smtp server port
port = 465,
-- enable tls, required for gmail smtp
secure = 'tlsv1_2',
to = { to }
-- fixup from field
local from = '<' .. tostring(settings.from) .. '>'
headers = {
subject = subject,
['From'] = from,
body = message
settings.from = from
settings.rcpt = to
res, err = smtp.send(settings)
return res,err
endCode: subject = 'E-mail test'
message = 'Testing e-mail'
res, err = mail('yourrecipient@gmail.com', subject, message) |
