HifiBerry REST API - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: HifiBerry REST API (/showthread.php?tid=3354) |
HifiBerry REST API - Kai-Roger - 09.05.2021 Hi. I normally control my HifiBerry amplifiers with NodeRed and the HifiBerry API. I now try to do the same with my LM5, but i just get an error code. I want to send % volume to the amplifier. Anyone here who knows what to adjust to get this to work? Code: http = require('socket.http')
ltn12 = require('ltn12')
body = require('json').encode({
percent = event.getvalue()
res, code = http.request({
url = 'http://192.168.1.91:81/api/volume',
method = 'POST',
headers = {
['Content-Length'] = #body,
source = ltn12.source.string(body)
log(res, code)HifiBerry API documentation: https://github.com/hifiberry/audiocontrol2/blob/master/doc/api.md Error: * arg: 1 * string: <!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN"> <html> <head> <title>Error: 500 Internal Server Error</title> <style type="text/css"> html {background-color: #eee; font-family: sans;} body {background-color: #fff; border: 1px solid #ddd; padding: 15px; margin: 15px;} pre {background-color: #eee; border: 1px solid #ddd; padding: 5px;} </style> </head> <body> <h1>Error: 500 Internal Server Error</h1> <p>Sorry, the requested URL <tt>'http://192.168.1.91:81/api/volume'</tt> caused an error:</p> <pre>Internal Server Error</pre> </body> </html> * arg: 2 * number: 500 RE: HifiBerry REST API - admin - 09.05.2021 Try adding ['Content-Type'] = 'application/json' header RE: HifiBerry REST API - Kai-Roger - 09.05.2021 (09.05.2021, 15:57)admin Wrote: Try adding ['Content-Type'] = 'application/json' header Sorry. I can't find out where in the script i can add that line. I only get Lua syntax error. RE: HifiBerry REST API - Erwin van der Zwart - 09.05.2021 headers = { ['Content-Length'] = #body, ['Content-Type'] = 'application/json', }, RE: HifiBerry REST API - Kai-Roger - 09.05.2021 (09.05.2021, 21:01)Erwin van der Zwart Wrote: headers = { Thanks. I was sure that i tried that, but apparently not :) Now i found a new problem. This part of the code did not work: Code: body = require('json').encode({
})But this this works: Code: body = '{"percent":"30"}'It would have been nice if i could use the event.getvalue. RE: HifiBerry REST API - admin - 10.05.2021 Code: body = require('json').encode({
percent = tostring(event.getvalue())
})RE: HifiBerry REST API - Kai-Roger - 10.05.2021 (10.05.2021, 06:30)admin Wrote: Works :) Thanks for great support! |
