Subtract 30 minutes from time value - 2021-05-12T19:30:00 - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Subtract 30 minutes from time value - 2021-05-12T19:30:00 (/showthread.php?tid=3365) |
Subtract 30 minutes from time value - 2021-05-12T19:30:00 - jamesng - 12.05.2021 Hi I receive time values from an API in the following format 2021-05-12T19:30:00 How can I subtract 30 minutes from the time (and also correct for date for when I receive midnight value?) Many thanks in advance James RE: Subtract 30 minutes from time value - 2021-05-12T19:30:00 - admin - 12.05.2021 Use this: Code: str = '2021-06-01T00:00:00'
date = {}
-- assign table keys for further conversion
date.year, date.month, date.day, date.hour, date.min, date.sec =
str:match('(%d+)-(%d+)-(%d+)T(%d+):(%d+):(%d+)')
-- convert to unix timestamp and subtract 30 minutes in seconds
timestamp = os.time(date) - 30 * 60
-- convert timestamp to table
date = os.date('*t', timestamp)
log(date)RE: Subtract 30 minutes from time value - 2021-05-12T19:30:00 - jamesng - 12.05.2021 Hi This seems to return the date as a table. Code: * table:
[sec]
* number: 0
[min]
* number: 0
[day]
* number: 12
[isdst]
* bool: false
[wday]
* number: 4
[yday]
* number: 132
[year]
* number: 2021
[month]
* number: 5
[hour]
* number: 19How can I convert this back to a string in the same format as the original time (ie: 2021-05-12T19:30:00 > 2021-05-12T19:00:00)? Many thanks James RE: Subtract 30 minutes from time value - 2021-05-12T19:30:00 - admin - 12.05.2021 Code: str = '2021-06-01T00:00:00'
date = {}
-- convert timestamp to string
result = os.date('%Y-%m-%dT%H:%M:%S', timestamp)
log(result)RE: Subtract 30 minutes from time value - 2021-05-12T19:30:00 - jamesng - 12.05.2021 This worked perfectly! Many thanks |
