Turning off scroll bouncing - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: OLD visualization (https://forum.logicmachine.net/forumdisplay.php?fid=9) +--- Thread: Turning off scroll bouncing (/showthread.php?tid=3370) |
Turning off scroll bouncing - Zandkever - 13.05.2021 Hi, I am using my visu with an iPad. Sometimes people have an issue with controlling the buttons on the screens, due to the fact that the whole screen is be ‘pushed’ slightly up and down - instead of buttons being pushed or sliders moved. In that case the screen bounces elastically. Also sometimes called ‘rubber-banding’ or ‘elastic scrolling’. Hope I am clear enough with my explanation. Though the issue is of course primarily with the user in how the the screen was touched, but having ipads installed on the wall or on a stand it hampers good control. I also see that other applications do not have this elastic effect. Is there a wayto turn off this elastic screen effect? RE: Turning off scroll bouncing - Daniel - 13.05.2021 Try Disable object click animation: in Vis config. RE: Turning off scroll bouncing - Zandkever - 13.05.2021 (13.05.2021, 08:14)Daniel. Wrote: Try Disable object click animation: in Vis config. No, unfortunately doesn’t solve it. RE: Turning off scroll bouncing - admin - 13.05.2021 Couple of things to try: 1. Add to Vis. graphics > Edit custom CSS: Code: html, body { overscroll-behavior: none; }2. Add to Scripting > Tools > Custom JavaScript: Code: /*! iNoBounce - v0.2.0
* https://github.com/lazd/iNoBounce/
* Copyright (c) 2013 Larry Davis <lazdnet@gmail.com>; Licensed BSD */
(function(global) {
// Stores the Y position where the touch started
var startY = 0;
// Store enabled status
var enabled = false;
var supportsPassiveOption = false;
try {
var opts = Object.defineProperty({}, 'passive', {
get: function() {
supportsPassiveOption = true;
window.addEventListener('test', null, opts);
} catch (e) {}
var handleTouchmove = function(evt) {
// Get the element that was scrolled upon
var el = evt.target;
// Allow zooming
var zoom = window.innerWidth / window.document.documentElement.clientWidth;
if (evt.touches.length > 1 || zoom !== 1) {
return;
// Check all parent elements for scrollability
while (el !== document.body && el !== document) {
// Get some style properties
var style = window.getComputedStyle(el);
if (!style) {
// If we've encountered an element we can't compute the style for, get out
break;
// Ignore range input element
if (el.nodeName === 'INPUT' && el.getAttribute('type') === 'range') {
return;
var scrolling = style.getPropertyValue('-webkit-overflow-scrolling');
var overflowY = style.getPropertyValue('overflow-y');
var height = parseInt(style.getPropertyValue('height'), 10);
// Determine if the element should scroll
var isScrollable = scrolling === 'touch' && (overflowY === 'auto' || overflowY === 'scroll');
var canScroll = el.scrollHeight > el.offsetHeight;
if (isScrollable && canScroll) {
// Get the current Y position of the touch
var curY = evt.touches ? evt.touches[0].screenY : evt.screenY;
// Determine if the user is trying to scroll past the top or bottom
// In this case, the window will bounce, so we have to prevent scrolling completely
var isAtTop = (startY <= curY && el.scrollTop === 0);
var isAtBottom = (startY >= curY && el.scrollHeight - el.scrollTop === height);
// Stop a bounce bug when at the bottom or top of the scrollable element
if (isAtTop || isAtBottom) {
evt.preventDefault();
// No need to continue up the DOM, we've done our job
return;
// Test the next parent
el = el.parentNode;
// Stop the bouncing -- no parents are scrollable
var handleTouchstart = function(evt) {
// Store the first Y position of the touch
startY = evt.touches ? evt.touches[0].screenY : evt.screenY;
var enable = function() {
// Listen to a couple key touch events
window.addEventListener('touchstart', handleTouchstart, supportsPassiveOption ? { passive : false } : false);
window.addEventListener('touchmove', handleTouchmove, supportsPassiveOption ? { passive : false } : false);
enabled = true;
var disable = function() {
// Stop listening
window.removeEventListener('touchstart', handleTouchstart, false);
window.removeEventListener('touchmove', handleTouchmove, false);
enabled = false;
var isEnabled = function() {
return enabled;
// Enable by default if the browser supports -webkit-overflow-scrolling
// Test this by setting the property with JavaScript on an element that exists in the DOM
// Then, see if the property is reflected in the computed style
var testDiv = document.createElement('div');
document.documentElement.appendChild(testDiv);
testDiv.style.WebkitOverflowScrolling = 'touch';
var scrollSupport = 'getComputedStyle' in window && window.getComputedStyle(testDiv)['-webkit-overflow-scrolling'] === 'touch';
document.documentElement.removeChild(testDiv);
if (scrollSupport) {
enable();
// A module to support enabling/disabling iNoBounce
var iNoBounce = {
enable: enable,
disable: disable,
isEnabled: isEnabled
if (typeof module !== 'undefined' && module.exports) {
// Node.js Support
module.exports = iNoBounce;
if (typeof global.define === 'function') {
// AMD Support
(function(define) {
define('iNoBounce', [], function() { return iNoBounce; });
}(global.define));
else {
// Browser support
global.iNoBounce = iNoBounce;
}(this));RE: Turning off scroll bouncing - Zandkever - 13.05.2021 Thanks guys, works like a charm! RE: Turning off scroll bouncing - admin - 13.05.2021 Did you try both at the same time? I'm wondering if only one solution is enough. RE: Turning off scroll bouncing - Zandkever - 14.05.2021 (13.05.2021, 14:21)admin Wrote: Did you try both at the same time? I'm wondering if only one solution is enough. I now ckecked option 1 and 2 seperately Option 2 does the trick. Option 1 doesn't. RE: Turning off scroll bouncing - admin - 14.05.2021 Ok, thanks for testing! 1st option should work but due to a bug in Safari it does not. |
