Analog Input Reactor - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Hardware (https://forum.logicmachine.net/forumdisplay.php?fid=12) +--- Thread: Analog Input Reactor (/showthread.php?tid=3381) |
Analog Input Reactor - Frank68 - 20.05.2021 Hello Should I acquire a signal from a resistive level (fuel) in the REACTOR can I use input 14, using the 5 V generated by the reactor itself, in case of resistance 0 the input is protected or better put a limiting resistor in series? Thanks so much RE: Analog Input Reactor - admin - 20.05.2021 Do you have a datasheet for this sensor? RE: Analog Input Reactor - Frank68 - 20.05.2021 (20.05.2021, 16:39)admin Wrote: Do you have a datasheet for this sensor? I use different types of sensors ranging from 180 to 300 ohms. depending on the manufacturer of the equipment. |
