openweathermap doesnt work anymore - Printable Version
+--- Thread: openweathermap doesnt work anymore (/showthread.php?tid=3384)
openweathermap doesnt work anymore - Dré - 23.05.2021
I use this script (i didn't make it by myself). in January, it stopped working, but i don't know why.
I tried the script on another location and Logic machine too, it doesn't matter.
The message i got is 'Weather: cannot fetch data. Status code: timeout' (what will generate at rule 55 till 55)  it looks like he cannot connect to the server, but i don't know why.
I think the problem is between rule 11 and 49, but I'm not sure.
Maybe someone knows where i have to look at?
I tried to see what is wrong at https://openweathermap.org/appid, but i don't see it.
require('json') require('socket.http') require("ltn12") socket.http.TIMEOUT = 10 --********************************************************** -->>>>>>>>>>>>>USER MODIFICATION AREA (BEGIN)<<<<<<<<<<<<<<< --********************************************************** local searchBy = 1 -- 0-search by city name; 1-search by cityID local city = 'Amsterdam, NL' --city name local cityID= '2759794' --city ID (see openweathermap.org) local timezone= 1 --add a timeshift of your timezone (eg. timezone = 2 for Prague) local units = 'metric' --units of measured values: metric/imperial local lang = 'NL' --[[language of weather description English - en, Russian - ru, Italian - it, Spanish - es (or sp), Ukrainian - uk (or ua), German - de, Portuguese - pt, Romanian - ro, Polish - pl, Finnish - fi, Dutch - nl, French - fr, Bulgarian - bg, Swedish - sv (or se), Chinese Traditional - zh_tw, Chinese Simplified - zh (or zh_cn), Turkish - tr, Croatian - hr, Catalan - ca --]] local proxy='http://10.154.24.21:8080/' --set proxy server e.g. 'http://10.10.10.10/'. If no proxy is needed set proxy=nil local apikey='HIDDEN'  --API key can be retrieved after registration on http://openweathermap.org/appid --********************************************************** -->>>>>>>>>>>>>USER MODIFICATION AREA (END)<<<<<<<<<<<<<<<<< --********************************************************** local data,_, code, headers, status, ret local proxyServer="http://10.154.24.21:8080/" local response = {} if searchBy==0 then _, code, headers, status = socket.http.request{     url='http://api.openweathermap.org/data/2.5/weather?q='..city..'&mode=json&units='..units..'&lang='..lang..'&APPID='..apikey,     sink = ltn12.sink.table(response),     proxy=proxy   } elseif searchBy== 1 then   _, code, headers, status = socket.http.request{     url='http://api.openweathermap.org/data/2.5/weather?ID='..cityID..'&mode=json&units='..units..'&lang='..lang..'&APPID='..apikey,     sink = ltn12.sink.table(response),     proxy=proxy   }     end if code==200 then   alert('Fetch OK') else   alert('Weather: cannot fetch data. Status code: '..code)   return end ret = table.concat(response) data = json.pdecode(ret) if not data then   alert('Weather: cannot parse data')   return end log(data) grp.update('12/0/1', (data.main.temp),dt.float16) --Current temperature [Celsius deg] grp.update('12/0/2', (data.main.temp_min),dt.float16) --Minimum temperature at the moment grp.update('12/0/3', (data.main.temp_max),dt.float16) --Maximum temperature at the moment grp.update('12/0/4', (data.main.pressure),dt.float16) --Atmospheric pressure (on the sea level, if there is no sea_level or grnd_level data), hPa grp.update('12/0/5', (data.wind.speed),dt.float16) --Wind speed, mps grp.update('12/0/6', (data.wind.deg),dt.angle) --Wind direction, degrees (meteorological) grp.update('12/0/7', (data.clouds.all),dt.scale) --Cloudiness [%] grp.update('12/0/8', (data.weather[1].id),dt.int16)--Weather condition ID grp.update('12/0/9', (data.weather[1].main),dt.string)--Group of weather parameters (Rain, Snow, Extreme) grp.update('12/0/10', (data.weather[1].description),dt.string)--Weather condition within the group grp.update('12/0/11', (data.weather[1].icon),dt.string)--Weather icon ID grp.update('12/0/12', (data.rain),dt.float16) --Precipitation volume for last 3 hours, [mm] grp.update('12/0/13', (data.snow),dt.float16) --Snow volume for last 3 hours, mm --set time shift base od day saving time if os.date("*t").isdst==false then   dst_timeshift= 0 else   dst_timeshift= 1 end --convert the sunrise time to KNX datatype format sunrise_time_hour=math.floor((data.sys.sunrise%86400)/3600) sunrise_time_min=math.floor(((data.sys.sunrise%86400)%3600)/60) sunrise_time_sec=(((data.sys.sunrise%86400)%3600)%60) sunrise_time={hour=sunrise_time_hour+timezone+dst_timeshift,minute=sunrise_time_min,second=sunrise_time_sec} --convert the sunset time to KNX datatype format sunset_time_hour=math.floor((data.sys.sunset%86400)/3600) sunset_time_min=math.floor(((data.sys.sunset%86400)%3600)/60) sunset_time_sec=(((data.sys.sunset%86400)%3600)%60) sunset_time={hour=sunset_time_hour+timezone+dst_timeshift,minute=sunset_time_min,second=sunset_time_sec} grp.update('12/0/14', (sunrise_time),dt.time) --sunrise time grp.update('12/0/15', (sunset_time) ,dt.time) --sunset time grp.update('12/0/16', data.coord.lon,dt.float16) --longitude grp.update('12/0/17', data.coord.lat,dt.float16) --latitude log("Fetch of current weather data done.")
Sorry I'm just a beginner who will try more with a Logic Machine.
openweathermap doesnt work anymore - tomnord - 23.05.2021
Yr.no has a smooth API you could look into.
Sent fra min SM-G980F via Tapatalk
RE: openweathermap doesnt work anymore - admin - 24.05.2021
Your script is using a proxy server. Is it really needed? Can LM access the internet directly?
RE: openweathermap doesnt work anymore - Dré - 24.05.2021
(24.05.2021, 09:32)admin Wrote: Your script is using a proxy server. Is it really needed? Can LM access the internet directly?
No it isn't needed, yesterday I already tried to use 'local proxy=nil' but it didn't had any effect, it still doesn't work.
Today i did do it again after your message, it works. But I did get 'cannot fetch data. Status code: 400' but i solved this part too today.
Maybe because both problems I didn't see the mistakes.
Simply thinks can have big problems
