Table and CSV - Printable Version
+--- Thread: Table and CSV (/showthread.php?tid=3407)
Table and CSV - Frank68 - 08.06.2021
Hello
I created a scrip that populates a 'MyPowerLog' table for me
below
data = storage.get('MyPowerLog', {})   table.insert(data, {     -- usare os.date formattare la stringa     ['time'] = os.time(),     ['Totale Attiva'] = grp.getvalue('4/0/108'),     ['Totale Reattiva'] = grp.getvalue('4/1/108'),   }) storage.set('MyPowerLog', data)
I should export it to CSV only the data of the last month as I can do
Furthermore, once the data has been exported, I should delete it in order not to have a continuous table that increases the space occupied dramatically. the script command to delete the table which is it?
Thanks so much
RE: Table and CSV - admin - 08.06.2021
Use this to delete the storage entry:
storage.delete('MyPowerLog')
RE: Table and CSV - Frank68 - 08.06.2021
(08.06.2021, 06:49)admin Wrote: Use this to delete the storage entry:
Where is the mistake?
i read data from my table, prepare csv header, look for data in my table and for each row i would like to add them to csv file, but nothing i have only headers.
--date.day, date.hour, date.min, date.sec = 1, 0, 0, 0 --ts_start = os.time(date) --date.month = date.month + 1 --ts_end = os.time(date) --PowTable = db:getall('SELECT * FROM MyPowerLog where time BETWEEN ? AND ? ORDER BY id DESC', ts_start, ts_end) PowTable = db:getall('SELECT * FROM MyPowerLog') -- csv buffer buffer = {} -- format csv row csv = string.format('%q,%q,%q', "Time", "Attiva", "Reattiva") -- add to buffer table.insert(buffer, csv) -- add empty line to buffer table.insert(buffer, "") -- Loop through PowTable for _, Measure in ipairs(PowTable) do   -- format csv row   csv = string.format('%q,%q,%q', os.date("%d.%m.%Y %X", Measure.time),Measure.Attiva, Measure.Reattiva )   -- add to buffer   table.insert(buffer, csv) end --Create attachment inside FTP server src = os.date('%Y-%m') .. '.csv' dst = '/home/ftp/' .. src io.writefile(dst, buffer)
i probably wrong something in the table reading loop but i can't figure out what.
thank you
Your log in not a database table but a storage entry, so use this:
PowTable = storage.get('MyPowerLog', {})
(08.06.2021, 08:40)admin Wrote: Your log in not a database table but a storage entry, so use this:
Found problem my error now work all
Thank
