time range verification - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: time range verification (/showthread.php?tid=3413) |
time range verification - Frank68 - 10.06.2021 Hello I'm trying with a script to check if I'm within a certain time frame, which crosses midnight. In practice, if I am in the range between 20.00 and 06.00 the next day I must have true. then I will replace the fixed values with settable values, which way to follow? Thanks so much RE: time range verification - Seijboldt - 10.06.2021 Here's an exerpt where I'm checking if the time is between 0200 and 0700 hours, you can modify this to do what you need. now = os.date('*t') time = {hour = now.hour,} if time.hour > 2 and time.hour < 7 then *do stuff* else *do stuff* end RE: time range verification - admin - 10.06.2021 The above example is correct but if you also need minutes in the range then check this example: https://forum.logicmachine.net/showthread.php?tid=1439&pid=21201#pid21201 RE: time range verification - Frank68 - 10.06.2021 (10.06.2021, 09:27)admin Wrote: The above example is correct but if you also need minutes in the range then check this example: https://forum.logicmachine.net/showthread.php?tid=1439&pid=21201#pid21201 tkank's |
