Bose Processor - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Bose Processor (/showthread.php?tid=3420) |
Bose Processor - YOUSSEF - 12.06.2021 Hello trying to control a bose processor ESP 880A via http request to set an input and change volume, https://firstandsecondhomes.com/assets/uploads/SoundTouchAPI_WebServices_v1.1.0.pdf i used this exemple found and i still get "connexion failed" http = require('socket.http') IP = '192.168.5.160' url = 'http://' .. IP .. ':8090/volume>$20' res, err = http.request(url) log(res, err) any insights ? RE: Bose Processor - admin - 14.06.2021 Can you ping this IP from LM (System config > Status > Network utilities)? Can you access this URL from your browser? The code for setting the volume is incorrect, use this: Code: http = require('socket.http')
volume = 20
data = '<volume>' .. volume .. '</volume>'
url = 'http://' .. IP .. ':8090/volume'
res, err = http.request(url, data)
log(res, err) |
