Safari guided access problem - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: OLD visualization (https://forum.logicmachine.net/forumdisplay.php?fid=9) +--- Thread: Safari guided access problem (/showthread.php?tid=3431) |
Safari guided access problem - Zandkever - 22.06.2021 Hello, I have a visu running on an ipad under guided access. I am running it via a safari-shortcut on the homescreen, which all works fine. Only after fully charging the ipad overnight, the ipad has exited the guided access mode. Also username and pw is required again when logging in. I believe it could be an automatic refresh of the safari cache or so, because also the username and pw is requested. Is this a known issue? Any idea/solution for this? thanks! RE: Safari guided access problem - Daniel - 23.06.2021 In user access settings set the:Remember username and password See if this helps. Other option is to use our starter app from the Store. RE: Safari guided access problem - Erwin van der Zwart - 23.06.2021 Keep in mind that this does not work for the admin user, only for the custom created users.. RE: Safari guided access problem - Zandkever - 24.07.2021 Thanks. The "User Access"-options make life much easier, either by - Disable password for Visualization, or - Remember username and password Unsolved is that ipad keeps kicking out of the Guided Access. The starter app is not an option since the it has a bar in the bottom that allows to navigate out of the visualization. |
