Opening Links inside a Frame - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: OLD visualization (https://forum.logicmachine.net/forumdisplay.php?fid=9) +--- Thread: Opening Links inside a Frame (/showthread.php?tid=3445) |
Opening Links inside a Frame - HannPark - 25.06.2021 Hi Guys, Hope everything´s OK in these difficult days... I'm making a Visu, and trying to make a left scroll menu, using a Frame with overflow in CSS I'd like to know if exist a way to Opening the links from inside the frame in the full page instead of the frame, looking for a full view and not this result Thank you guys in advance B.R. RE: Opening Links inside a Frame - admin - 26.06.2021 I suggest using the standard menu in docked mode (you can set this in Vis. configuration) and adjust it via CSS as needed. |
