Can I use a script to edit other script? - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Can I use a script to edit other script? (/showthread.php?tid=3448) |
Can I use a script to edit other script? - pouralise - 27.06.2021 Can I use aa event-base script to edit other event-base script? If I can, please help me to do that, better with a simple excample. Many thanks RE: Can I use a script to edit other script? - admin - 28.06.2021 See this: https://forum.logicmachine.net/showthread.php?tid=3421 RE: Can I use a script to edit other script? - pouralise - 28.06.2021 Nice, thank you. But I have a question that if I dont want to edit the script by ID but by object, how can I do it? For example, in object tab, I click to object 0/0/1 event script to edit script and it's "scada-main/main/editor?object=1" but in scripting tab, it's "scada-main/main/editor?id=15". They are the same but I want to edit the script by knowing it's object address instead of ID. And how can I add a new script like this: name =1, group address = 10/7/1, active = true like in the screenshot
RE: Can I use a script to edit other script? - pouralise - 29.06.2021 I find a solution, thank you |
