Best way to decode Modbus - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Best way to decode Modbus (/showthread.php?tid=3450) |
Best way to decode Modbus - gtsamis - 29.06.2021 Hi, I have a DSE7320 power generator controller and i need to read some alerts. I use Modbus mapper to store the alert registers to virtual objects and then decode them with script. Code: dword ='0x'.. event.datahex
myobject = grp.find(event.dstraw)
function getbit(value, nr)
value = bit.rshift(value, nr)
return bit.band(value, 1)
for i = 0, 15, 4 do
obj=math.floor((i+1)/4)
msg=''
val=''
for x = 0, 3, 1 do
ix=i+x
val = getbit(dword,ix)..val
bin = string.reverse(val)
local sum = 0
for i = 1, string.len(bin) do
num = string.sub(bin, i,i) == "1" and 1 or 0
sum = sum + num * math.pow(2, i-1)
msg=msg .. ' Bin:'..val..' Dec:'.. sum
obj=obj..msg
alert(myobject.name..'-'..obj)
endCan someone please verify if this is the most eficient way or sugest something better? Thank you in advance George RE: Best way to decode Modbus - admin - 30.06.2021 The most correct way to do this is via bit shifts (bit.rshift and bit.band) but since you need to split the value into 4 bit values you can simply use the datahex string: Code: value = event.datahex
values = {}
for i = 1, 4 do
char = value:sub(i, i)
values[ i ] = tonumber(char, 16)
log(values) |
