Mosaic 3.0 widget decimals - Printable Version
+--- Thread: Mosaic 3.0 widget decimals (/showthread.php?tid=3473)
Mosaic 3.0 widget decimals - krosa - 14.07.2021
Hi to all,
I was searching on the forum for mosaic 3.0 custom widgets and decimals but I can't find a solution.
We built a custom widget with a 2 bytes float temperature value but we would like to display only 1 decimal instead of the 2 it displays now... there's a way to achieve it?
Thank you
RE: Mosaic 3.0 widget decimals - fleeceable - 22.07.2021
Same problem here...
EDIT: After Mosaic 3 beta update (version: 20210726) I found that if you declare your group address as 2 byte floating point then one digit is shown. Looks like dev-s fixed it.
If you declare GA as Temperature - no digits at all.
