FTP Limitation - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: FTP Limitation (/showthread.php?tid=3486) |
FTP Limitation - BrentW - 23.07.2021 I am using the Clipsal/Schneider NAC platform here in Australia and have come across a problem with the FTP library. The client I am working with requires the use of SFTP as I do not have a certificate for the NAC. This library as I understand is part of a later release. The problem I face is that Clipsal has not released a firmware update for a very long time and track records for this indicate that it will not improve. I adore this product but it is being held back substantially by this OEM arrangement. Is there a method by which I can use the FTP library but skip the certificate error and continue the upload? The error I'm receiving back is "550 SSL/TLS required on the control channel" Any assistance would be greatly appreciated. I note the work around for other SFTP was to install an IPK. this is not an option on the Nac/Shac as I understand it? Thanks in advance, Brent RE: FTP Limitation - admin - 23.07.2021 There's not much we can do because new firmware releases are Clipsal/Schneider responsibility. Unfortunately separate package upgrade won't work because LuaSocket depends on newer OpenSSL which is used by many other packages. So it will break a lot of other system components if upgraded. You can try replacing the FTP module with a new version via a script (run once, make sure that your device has valid gateway and DNS set): Code: os.execute('wget -O /usr/lib/lua/socket/ftp.lua http://dl.openrb.com/misc/ftp.lua')RE: FTP Limitation - BrentW - 24.07.2021 (23.07.2021, 06:14)admin Wrote: There's not much we can do because new firmware releases are Clipsal/Schneider responsibility. Thanks for the prompt reply. I will give this method a try when i'm next on site. Certainly understand the limitations you have with firmware rollouts. Brent RE: FTP Limitation - Daniel - 26.07.2021 As far I know Clipsal is planing new fw release in September. RE: FTP Limitation - BrentW - 26.07.2021 (26.07.2021, 07:45)Daniel. Wrote: As far I know Clipsal is planing new fw release in September.I certainly hope this is the case. Such a great product its a shame to see such a big delay on updates. Brent |
