Mosaic Access - Printable Version
+--- Thread: Mosaic Access (/showthread.php?tid=3505)
Mosaic Access - Frank68 - 09.08.2021
Hello
I am using mosaic 3.0, but I have a problem with End User viewing.
If I don't give full access the user can't see anything.
HW: LM5 Lite (i.MX6)
SW: 20210510
Access via dyndns, do I have to use the cloud?
Where am I wrong?
thank you very much
RE: Mosaic Access - Daniel - 09.08.2021
Via port forward it still should work. Can he access it locally?
From outside you should use cloud for security reasons.
RE: Mosaic Access - Frank68 - 09.08.2021
(09.08.2021, 08:44)Daniel. Wrote: Via port forward  it still should work. Can he access it locally?
I am connected with Zerotier on the device but if I have partial access it does not work.
From outside, then I must necessarily use the cloud and register a user on it, where can I find a configuration guide for the new cloud?
Thanks Daniel for the support
https://forum.logicmachine.net/showthread.php?tid=3263&pid=21069#pid21069
