Writing string with grp.write or grp.update fails - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Writing string with grp.write or grp.update fails (/showthread.php?tid=352) |
Writing string with grp.write or grp.update fails - jdboer - 24.07.2016 I'm writing a script to consume a AERIS api. I als want to save the ISO date time strings in an object so I do not have to decode the unix timestamps to see which value it is. In the script I use 'grp.write('0/0/104', response1.dateTimeISO , dt.string)' But the script fails/crashes as soon it is writing a string value. Also tried using 'grp.update', and pre-create the objects, and leaving out the 'dt.string' type, but everything fails. Even 'grp.write('0/0/104', 'testing', dt.string) fails. Is it not possible to write string values? I see it's being used on other scripts so what am I doing wrong? I'm running a LM2 with firmware 20130927 (Unfortunately there does not seem to be a newer firmware for LM2 :-( ) RE: Writing string with grp.write or grp.update fails - admin - 25.07.2016 This one is the latest for LM2 (2015.09.17): https://dl.openrb.com/lm-15.09/lm2-at91.img |
