set value 5000 on float16 becomes 4999.68 - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: set value 5000 on float16 becomes 4999.68 (/showthread.php?tid=3530) |
set value 5000 on float16 becomes 4999.68 - spyder - 27.08.2021 Can you help? I defined a group object of type float16 (09. 2 byte floating point). When I set the value (manually or via /cgi-bin/scada-remote/request.cgi) to 5000, I get 4999.68. There are no event scripts attached to the group object. I am running on: HW: Reactor v2 (i.MX28) SW: 20200720 What am I doing wrong? RE: set value 5000 on float16 becomes 4999.68 - admin - 27.08.2021 float16 has limited precision so you can't get 5000 precisely. If possible use float32 or int16. RE: set value 5000 on float16 becomes 4999.68 - spyder - 28.08.2021 (27.08.2021, 12:20)admin Wrote: float16 has limited precision so you can't get 5000 precisely. If possible use float32 or int16. ok, I understand - thanks! |
