Script that reads from the bus and write - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Script that reads from the bus and write (/showthread.php?tid=3537) |
Script that reads from the bus and write - streilkx - 31.08.2021 Hello there, Could you help me with a script that reads from the bus, every 10 minutes, the value (1 byte,%) of the object 2/3/11 and writes it back to the bus? Thanks for help! RE: Script that reads from the bus and write - Kapudan - 31.08.2021 Add a resident script with sleep interval 600 value = grp.getvalue('2/3/11') grp.write('2/3/11', value) RE: Script that reads from the bus and write - admin - 31.08.2021 Resident cannot have a delay larger than 60 seconds. Use a scheduled script instead. If you want to send a read request periodically just set poll interval in object properties. RE: Script that reads from the bus and write - Kapudan - 31.08.2021 (31.08.2021, 16:22)admin Wrote: Resident cannot have a delay larger than 60 seconds. Use a scheduled script instead. If you want to send a read request periodically just set poll interval in object properties. Sorry, I didn't know. What about a resident script like this: value = grp.getvalue('2/3/11') grp.write('2/3/11', value) os.sleep(600) ? RE: Script that reads from the bus and write - admin - 31.08.2021 This will work as well RE: Script that reads from the bus and write - streilkx - 01.09.2021 (31.08.2021, 16:22)admin Wrote: Resident cannot have a delay larger than 60 seconds. Use a scheduled script instead. If you want to send a read request periodically just set poll interval in object properties. where can i find this? Is a value regulation. I need the value to be written periodically, not just after a change, detector does not have the optionĀ
RE: Script that reads from the bus and write - admin - 01.09.2021 But this is only for reading, you still need a script for writing. |
