Widget issues - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: OLD visualization (https://forum.logicmachine.net/forumdisplay.php?fid=9) +--- Thread: Widget issues (/showthread.php?tid=3553) |
Widget issues - pioneersteffen - 12.09.2021 Hi @all, I’m starting to generate a widget based visualization and I having three issues:
Many thanks in advance. Best Regards Steffen RE: Widget issues - Daniel - 13.09.2021 Movement is 1 bit up/down object. Look on SE shutter actuator. Humidity is 1byte object here. You can use widget creator and build it your own. RE: Widget issues - pioneersteffen - 13.09.2021 Many thanks for the help. Movement: I‘ve thought the up/down object was meant but why ever it didn‘t work yesterday. I tried it again today and now it is working fine with Object 23 in the MDT Docu. Humidity: I will try to adjust the existing and coming back to you. |
