Scandinavian Electric PM - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: Scandinavian Electric PM (/showthread.php?tid=3563) |
Scandinavian Electric PM - FatMax - 16.09.2021 I'm trying to read some values from a modus gateway connected to a energy meter. The documentation leaves a lot to be desired however; I've converted the Address to 1848, 1850 and 1852. I'm not getting any data through my profile though. Could anyone with the correct knowledge look through my profile to see if I have interpreted the documentation correctly? http://docs.circutor.com/docs/M014B01-03.pdf <-- Link to device documentation. I have communication with it as I'm getting data when I try to read through the testing tools on the SL. RE: Scandinavian Electric PM - Daniel - 16.09.2021 Delete this value_nan and check again. What were the settings when you were reading via test read? RE: Scandinavian Electric PM - FatMax - 17.09.2021 (16.09.2021, 14:39)Daniel Wrote: Delete this value_nan and check again. What were the settings when you were reading via test read? I'll try that! Settings where 9600, None (1 stop bit) and half duplex. RE: Scandinavian Electric PM - admin - 17.09.2021 Have you tried using uint32 instead of float32 for bus_datatype? For current/phase use 0.01 multiplier (two decimal places). RE: Scandinavian Electric PM - FatMax - 17.09.2021 We did try that, but the value corresponded more with real life when I used float. (In the RTU testing tool) RE: Scandinavian Electric PM - admin - 17.09.2021 Try uint32 with the test tool and also try different swap modes. RE: Scandinavian Electric PM - FatMax - 17.09.2021 value_nan removal did not make a difference. Will test further with different swap modes. What's weird though is that I'm getting data with the test tool, but nothing when mapping it to a GA. |
