Mosaic: RGBW dimmer - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: OLD visualization (https://forum.logicmachine.net/forumdisplay.php?fid=9) +--- Thread: Mosaic: RGBW dimmer (/showthread.php?tid=3582) |
Mosaic: RGBW dimmer - Domoticatorino - 24.09.2021 Hi, is there a reason why in the object "RGBW dimmer" there is no the "White status value feedback object"? Thanks. BR RE: Mosaic: RGBW dimmer - Daniel - 27.09.2021 Because white is calculated from red,green, blue values so the feedback would be ignored anyway. RE: Mosaic: RGBW dimmer - Domoticatorino - 27.09.2021 (27.09.2021, 08:16)Daniel Wrote: Because white is calculated from red,green, blue values so the feedback would be ignored anyway. Hi Daniel, I am not totally agree with you. There are Knx devices which manage spotlight and strip led RGBW. The White in that case Is not made of RGB but there is the forth Channel for white light only. It this case the feedback object for White It Is necessary. |
