Yamaha Extended Control - Printable Version
+--- Thread: Yamaha Extended Control (/showthread.php?tid=3602)
Yamaha Extended Control - akn - 04.10.2021
I can send HTTP a request to the Yamaha controller.
http://ip_address/YamahaExtendedControl/v1/main/getStatus
After the request, I receive an answer. For example when "power": "ON", the controller is on, and when "power": "standby" the controller is off.
{"response_code":0,"power":"standby","sleep":0,"volume":100,"mute":false,"max_volume":161,"input":"airplay","input_text":"AirPlay","distribution_enable":false,"enhancer":true,"equalizer":{"mode":"auto","low":0,"mid":0,"high":0},"bass_extension":false,"link_control":"standard","link_audio_delay":"balanced","disable_flags":0,"actual_volume":{"mode":"db","value":-30.5,"unit":"dB"},"mono":false}
Tell me how I can convert the received data to the KNX?
RE: Yamaha Extended Control - admin - 05.10.2021
Use this as a starting point. response variable should contain your HTTP request result.
status = require('json').pdecode(response) if type(status) == 'table' then   poweron = status.power ~= 'standby'   grp.checkupdate('1/1/1', poweron) -- power status (1 bit)   grp.checkupdate('1/1/2', status.input_text) -- input (text)   volume = status.volume / status.max_volume * 100   grp.checkupdate('1/1/3', volume) -- current volume (1 byte scale) end
RE: Yamaha Extended Control - akn - 05.10.2021
thanks.
RE: Yamaha Extended Control - akn - 07.10.2021
Volume status problem!
The volume volume status is 100 but received volume value is 61
Therefore, the script is constantly updating the value.
RE: Yamaha Extended Control - admin - 07.10.2021
Try using the volume value directly. Also you should use different objects for status and control.
grp.checkupdate('1/1/3', status.volume)
