UIO8 and UIO20 error - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Hardware (https://forum.logicmachine.net/forumdisplay.php?fid=12) +--- Thread: UIO8 and UIO20 error (/showthread.php?tid=3606) |
UIO8 and UIO20 error - pouralise - 08.10.2021 Hi. Currently I'm doing 3 project, with LM5, UIO20 and UIO8. But problems appear with those UIO device. When I received the device, I can download the address and application through it from ETS. And when I installed them on my customer cabinet, it works normally. But after sometime (less than 1 month to 2 month), 5/6 the device are not working. ETS can't find the UIOs address on KNX bus, I can still press the learning button of the UIOs, but in ETS, it shows no device in programing mode too. And all the Input/output of the UIOs don't working too. Each of UIOs has it's owned 24V power supply, and the KNX bus working normally. I try to use the same power supply and knx bus for the device SA42M and no problem appear like UIOs. I think the UIOs has some error that break the KNX input. Those image below is screenshot of the LM5, UIO20 and UIO8 that I use. All the project use the same LM and UIOs as screenshot belows. Do you have any idea about what cause the problem? 1st project use 2 UIO8 and those both not working 2nd project use 2 UIO20 and 1 UIO8, and those 2 UIO20 not working, only 1 UIO 8 still working 3rd project use 1 UIO20 and 1 UIO8, and UIO 20 is not working, only UIO8 still working ![]() ![]() ![]()
RE: UIO8 and UIO20 error - Daniel - 08.10.2021 We would need to get them back to the office for analyses. Contact our office via email for replacement. |
