LM5lite KNX Test and updated Documentation? - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: LM5lite KNX Test and updated Documentation? (/showthread.php?tid=3634) |
LM5lite KNX Test and updated Documentation? - hstampfl - 20.10.2021 I have a LogicMachine lite installed. I did the initial configuration and enabled KNX IP feature. Is it possible to thest the KNX Bus if the connection is ok? Second small question is there an updated Documentation? Regards Heinz RE: LM5lite KNX Test and updated Documentation? - Daniel - 21.10.2021 You will see KNX connection status in bottom right corner if TP-UART mode is enabled. Latest docs are on our site under each product. RE: LM5lite KNX Test and updated Documentation? - hstampfl - 21.10.2021 Thank you. I got it. I asked regarding the updated documentation because on the documents first page is noted "Document Issue 1.0 November, 2016". Regards Heinz |
