homelynk without modbus - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: homelynk without modbus (/showthread.php?tid=3644) |
homelynk without modbus - bvb - 25.10.2021 Hi, I have a device(charger), that does not work with Modbus, there is any other way to insert it in homelynk and handle it with knx? RE: homelynk without modbus - Daniel - 25.10.2021 Check what other options your device has and let us know then we can recommend best. RE: homelynk without modbus - bvb - 25.10.2021 (25.10.2021, 12:27)Daniel Wrote: Check what other options your device has and let us know then we can recommend best.It uses ocpp protocol to communicate between charge point and charger. Maybe, i can use json, for my purpose? RE: homelynk without modbus - Daniel - 25.10.2021 This is quite complex topic and there is no quick solution. We will look in to it to see if we could do something. Would you be willing to let us test it on your charger if we decided to work on it? |
