MySQL packages - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: MySQL packages (/showthread.php?tid=3657) |
MySQL packages - ikhy - 31.10.2021 Hi! I want to insert data into MySQL database. When I install MySQL packages, I see this error. What is wrong? My version 20210521. RE: MySQL packages - admin - 01.11.2021 You are installing wrong packages. You can check your CPU type in System config > Upgrade firmware: If it says (i.MX6) then you need these packages: https://dl.openrb.com/lm-21-imx6/pkg/ Otherwise use these: https://dl.openrb.com/lm-21-mxs/pkg/ RE: MySQL packages - ikhy - 01.11.2021 thank you very much! |
