Number codes json modbus - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: Number codes json modbus (/showthread.php?tid=3660) |
Number codes json modbus - Peter S - 02.11.2021 Hi, I have a SMA inverter that gives different code numbers depending on status via modbus. Address: 30201 303=OFF 307=OK 455=Warning 35=FAULT. I would like to convert it to 1bit signals and make up 4 different group addresses, one for each signal. What is the best solution for this? Is it possible to convert it in the json file? Or is it better to make a script? "name": "Status of device", "bus_datatype": "uint32", "type": "register", "address": 30201, "datatype": "int32" Any help is much appreciated. Peter RE: Number codes json modbus - admin - 03.11.2021 You can map numbers to text value via Custom values for display but you cannot split such value into 4 bit objects without a script. The event script is very simple though: Code: value = event.getvalue()
grp.checkwrite('1/1/1', value == 303) -- OFF
grp.checkwrite('1/1/2', value == 307) -- OK
grp.checkwrite('1/1/3', value == 455) -- Warning
grp.checkwrite('1/1/4', value == 35) -- Fault |
