TP load flooding Bus - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: General (https://forum.logicmachine.net/forumdisplay.php?fid=2) +--- Thread: TP load flooding Bus (/showthread.php?tid=3672) |
TP load flooding Bus - ricole87 - 09.11.2021 Hi everyone, I found it strange on my LM that every-time a telegram send to bus for an event always cost least 10 telegrams which make TP load spikes. My TP load always not flat and stable. Could anyone give a hint on this situation. Best thank you RE: TP load flooding Bus - Daniel - 09.11.2021 Do you have another KNX router connected there? Could be KNX loop. RE: TP load flooding Bus - ricole87 - 09.11.2021 (09.11.2021, 14:43)Daniel Wrote: Do you have another KNX router connected there? Could be KNX loop. Yes D! I have only 1 KNX Secure router work as IP gateway to the Bus. Is this because of this ? If i take it out. How the KNX bus be accessible from Lan ? RE: TP load flooding Bus - Daniel - 09.11.2021 Change the multicast on LM then both can work together. Why do you need this extra router when LM can do the same? RE: TP load flooding Bus - ricole87 - 09.11.2021 (09.11.2021, 15:13)Daniel Wrote: Change the multicast on LM then both can work together. Why do you need this extra router when LM can do the same? I got this now D, i never know such! Very simple and great device, LM. Thank you for you support! Have a good day. |
