mosaic problem ? - Printable Version
+--- Thread: mosaic problem ? (/showthread.php?tid=3705)
mosaic problem ? - Frank68 - 24.11.2021
Hello
I have a [problem on a wiser, using touch/mosaic I can't control devices, if instead I do the X at the top right to reload the page it works, from the PC everything works, do you know if it's a normal problem on phones?
RE: mosaic problem ? - Daniel - 24.11.2021
Most likely websocket is blocked. How are you connecting?
RE: mosaic problem ? - Frank68 - 24.11.2021
(24.11.2021, 12:03)Daniel Wrote: Most likely websocket is blocked. How are you connecting?
I connect to ADSL, the provider says the port is open
Do you use Wiser app on your mobile?
(24.11.2021, 14:12)Daniel Wrote: Do you use Wiser app on your mobile?
I need  connect for programming in remote, with ETS5 , what is the solution to be adopted in order to do it, fw 2.6.1
No solution for SE devices. It is SE decision to completely block this functionality. We cannot(not allowed) to help you. In LM we have solution for this.
