BACnet server - object names - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: BACnet server - object names (/showthread.php?tid=372) |
BACnet server - object names - zoltan - 16.08.2016 Hi! I'm in the process of setting up a BACnet server with LM. The problem is the client device can't accept the names generated by LM. The object name is generated like this Code: 2 (AV) 2048 Temperatura_sobe_A138 (1.0.0) 23.1My client need a address defined [127001]Temperatura_sobe_A138, but the generated name has space in the middle, and throws an error. Any way to set the format by myself? Or disable the address part? I'm using LM ver. 20150917, bacnet 0.6.0-12 RE: BACnet server - object names - admin - 17.08.2016 In RC1 firmware BACnet object names does not have address appended by the default. Keep in mind, there are some bugs in RC1, specifically an issue with trends upgrade. RC2 will be out soon with fixes included. RE: BACnet server - object names - zoltan - 17.08.2016 (17.08.2016, 06:24)admin Wrote: In RC1 firmware BACnet object names does not have address appended by the default. Keep in mind, there are some bugs in RC1, specifically an issue with trends upgrade. RC2 will be out soon with fixes included. That's not a problem here. I'm using it only as BACnet/KNX gateway. I'll install the RC1 tomorrow and see if this works. In RC1, can we edit the object names, or they are generated by the system? RE: BACnet server - object names - admin - 17.08.2016 BACnet uses object name which you can edit by clicking any object in Objects tab. The only limitation is that object name must be unique. RE: BACnet server - object names - zoltan - 19.08.2016 Just to report back - the new RC1 works as expected om LM4! |
