OVERLOAD TP - Printable Version
+--- Thread: OVERLOAD TP (/showthread.php?tid=3722)
OVERLOAD TP - Frank68 - 02.12.2021
Greetings
I have a problem since yesterday without modifying anything, the LM goes into overload
thanks a lot
Greetings
thanks a lot
one of image is wrong
RE: OVERLOAD TP - Daniel - 02.12.2021
Seems you have high bus load. Try to debug why.
A lot of repeats. Looks like KNX loop.
RE: OVERLOAD TP - Frank68 - 02.12.2021
(02.12.2021, 08:38)Daniel Wrote: A lot of repeats. Looks like KNX loop.
some idea to find why ?
I have change nothing in programm.
RE: OVERLOAD TP - admin - 02.12.2021
Connect using ETS and check which device is sending a lot of telegrams
Usually it happens when there is second IP router connected. I know nothing about your project so hard to say.
Change KNX multicast and see if ti helped
Actually IP shows 0 so this is probably a script loop or something on KNX side
