Mosaic User rights - Printable Version
+--- Thread: Mosaic User rights (/showthread.php?tid=3726)
Mosaic User rights - tomnord - 03.12.2021
Hello. I've made a simple visu in mosaic so my customer can change color on som RGB lights.
Everything works fine from my computer when connected directly to the LM.
When customer connects via vpn software "citrix" directly to the mosaic url he is asked for credentials, he enters these and gets access to mosaic, but he does not seem to have write rights to the objects. When he changes color, it goes right back to the spot it was before.
RE: Mosaic User rights - admin - 03.12.2021
Probably the Websocket connection is not established. Check if Mosaic has a green dot in the bottom left corner.
RE: Mosaic User rights - Daniel - 03.12.2021
Why don't you just use our cloud for the customer. No need for VPN.
RE: Mosaic User rights - tomnord - 03.12.2021
(03.12.2021, 08:49)Daniel Wrote: Why don't you just use our cloud for the customer. No need for VPN.
It's on a secure technical network with no internet connection.
I will check the websocet. what needs to be enabled if that is the case?
It has to be configured on the VPN side. This might be relevant: https://msandbu.org/setting-up-websocket-access-on-citrix-netscaler/
see attached
