homelynk web: ERR_CONNECTION_REFUSED - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: General (https://forum.logicmachine.net/forumdisplay.php?fid=2) +--- Thread: homelynk web: ERR_CONNECTION_REFUSED (/showthread.php?tid=3740) |
homelynk web: ERR_CONNECTION_REFUSED - Tue - 12.12.2021 Hello there I got a problem. With out changing anything in my system for the past 6-8 months. (have not used the web interface for long). when I now on my internal IP network try to access my homelynk server I get this error message from browser (tried several different browsers and computers). ERR_CONNECTION_REFUSED I have tried to power cycle the unit. The unit is HW version 1.xx. All functions om KNX scripting works fine (all the one I have programmed over time and use everyday, KNX functions, mail functions when snail mail receives in post box). I can also program KNX units using the homelynk as a bridge from LAN to KNX… Open for ideas, what is wrong? BR Tue RE: homelynk web: ERR_CONNECTION_REFUSED - Daniel - 13.12.2021 Did you try accessing it with direct URL. http://IP/scada-main RE: homelynk web: ERR_CONNECTION_REFUSED - Tue - 13.12.2021 (13.12.2021, 08:37)Daniel Wrote: Did you try accessing it with direct URL. Hi there Thx, but yes I did, same problem BR Tue RE: homelynk web: ERR_CONNECTION_REFUSED - Daniel - 13.12.2021 It looks like some file system are corrupted. If you can't access web server then only thing is new card and complete re flash. RE: homelynk web: ERR_CONNECTION_REFUSED - Tue - 13.12.2021 (13.12.2021, 14:48)Daniel Wrote: It looks like some file system are corrupted. If you can't access web server then only thing is new card and complete re flash. OK, do you have a link or anything how to? I´m new in flash how to... BR Tue RE: homelynk web: ERR_CONNECTION_REFUSED - Daniel - 14.12.2021 https://openrb.com/reflash-logicmachine3-and-streaming-player-software/ Use this image for recovery http://dl.openrb.com/recovery.img.gz SE has application note for this too. |
