Modbus uint32 - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: Modbus uint32 (/showthread.php?tid=3741) |
Modbus uint32 - tomnord - 13.12.2021 Hello. When reading a HoldingReg with datatype uint32 from "readtest" I get this respond as attached image. But when integratin via JSON and datatype "12" I get a large number.. tried different datatypes, with no change.. any ideas what to try? RE: Modbus uint32 - Daniel - 13.12.2021 did you set "datatype": "uint32" ? RE: Modbus uint32 - tomnord - 13.12.2021 (13.12.2021, 12:53)Daniel Wrote: did you set "datatype": "uint32" ? yes. {"bus_datatype":"uint32","bus_address":"4/2/12","address":43418,"value_nan":[65472,0],"type":"register","read_count": 1,"value_multiplier":1,"units":"h","name":"15EP_OP","datatype":"uint32"}, {"bus_datatype":"uint32","bus_address":"4/2/6","address":43420,"value_nan":[65472,0],"type":"register","read_count": 1,"value_multiplier":1,"units":"h","name":"14EP_OP","datatype":"uint32"}, RE: Modbus uint32 - Daniel - 13.12.2021 Remove read_count": 1 RE: Modbus uint32 - tomnord - 13.12.2021 (13.12.2021, 13:14)Daniel Wrote: Remove read_count": 1 still same result.. RE: Modbus uint32 - Daniel - 13.12.2021 Are you sure that address is correct? "address":43418, in the image it is 3418 |
