DALI commands - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: DALI commands (/showthread.php?tid=3746) |
DALI commands - Aven - 14.12.2021 Hello! Please give me full list available commands for DALI gateway. This is very shortest list of commands: https://openrb.com/docs/dali.htm RE: DALI commands - Daniel - 14.12.2021 This is full list for the internal or RS485 dali gateway. If you use canX DALI then all commands are in the app. What are you looking for? RE: DALI commands - admin - 14.12.2021 DT8 commands are not documented there, number in brackets is DALI command number: Code: setdtr1 (195) set dtr1, similar to setdtr
setdtr2 (197) set dtr1, similar to setdtr
setx (224)
sety (225)
activate (226)
stepupx (227)
stepdownx (228)
stepupy (229)
stepdowny (230)
setcolortemp (231)
colortempcooler (232)
colortempwarmer (233)
setprimarydimlevel (234)
setrgbdimlevel (235)
setwafdimlevel (236)
setrgbwafcontrol (237)
copyreport (238)
storetyprimary (240)
storexyprimary (241)
storecolortemplimit (242)
storegearfeatures (243)
assigncolortolinked (245)
startautocalibration (246)
querygearfeatures (247)
querycolorstatus (248)
querycolorfeatures (249)
querycolorvalue (250)
queryrgbwafcontrol (251)
queryassignedcolor (252)RE: DALI commands - Aven - 14.12.2021 (14.12.2021, 09:58)Daniel Wrote: This is full list for the internal or RS485 dali gateway. If you use canX DALI then all commands are in the app. Commands for lua scripts. Do these gateways have different commands? CanX DALI have good app! But there are not all the possibilities. (14.12.2021, 10:14)admin Wrote: DT8 commands are not documented there, number in brackets is DALI command number: Thanks! Have extended DT1 (emergency test, battery status, etc) and DT6 & DT50,DT51,DT52 (Energy Reporting, diagnostics, etc) commands? RE: DALI commands - admin - 14.12.2021 No but you can send custom commands by using "raw" command. See these posts: https://forum.logicmachine.net/showthread.php?tid=2737 https://forum.logicmachine.net/showthread.php?tid=1500 RE: DALI commands - Aven - 14.12.2021 One more question. I have a mix of RS485 and canX DALI. Is there any way to connect the DALI-2 panel that sends Input Notification? RE: DALI commands - admin - 14.12.2021 CANx-DALI sends all received bus telegrams which you can get capture via a script and parse as needed: Code: if not canx then
canx = require('applibs.canx')
canx.getlistener(1)
function parse(frame)
local hdr = frame:byte(1) or 0
local typ = bit.rshift(hdr, 4)
local len = bit.band(hdr, 0x3)
-- bus data frame type
if typ == 7 and len > 0 then
loghex(frame)
canx.step(function(msg)
-- message from CANx device 0.1
if msg.lineid == 0 and msg.nodeid == 1 and msg.objectid == 1
and msg.frombus and type(msg.data) == 'string' then
parse(msg.data)
end) |
