Script not working - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: General (https://forum.logicmachine.net/forumdisplay.php?fid=2) +--- Thread: Script not working (/showthread.php?tid=3749) |
Script not working - thomasoppida - 15.12.2021 Hi, I have a problem with running scripts on my LM5 lite. I have tried to create very simple resident and event scripts with no luck. Updated LM5 to version 20211014. The LM5 is brand new. I have only integrated some modbus rtu and mapped these to groupadresses. This works. Created a simple eventscript to update the value to another group address. This does not do anything. Created also a resident script every 5 second to write test to the log. No response. I have another LM5 were I tested the same, this worked. Is there some corrupt packages? I can se in running processes all my lua resident scripts running and also using cpu. Nothing in systemlog. KR Thomas RE: Script not working - Daniel - 15.12.2021 Post your script and use logs to check where could be issue. RE: Script not working - thomasoppida - 15.12.2021 (15.12.2021, 09:29)Daniel Wrote: Post your script and use logs to check where could be issue. Same resident script running on two different LM's.. I have enabled/disabled and also rebooted RE: Script not working - Daniel - 15.12.2021 Can you provide remote access. Use zerotier if it will work
RE: Script not working - thomasoppida - 15.12.2021 (15.12.2021, 11:31)Daniel Wrote: Can you provide remote access. Use zerotier if it will work Yes. Do u have a network ID? RE: Script not working - Daniel - 15.12.2021 This case is sorted. Script in user library with autoload enabled... |
