Logic Machine Forum
[OLD] LogicMachine firmware 2021.12 - Printable Version
+-- Forum: Announcements (https://forum.logicmachine.net/forumdisplay.php?fid=7)
+--- Forum: Software updates (https://forum.logicmachine.net/forumdisplay.php?fid=13)
+--- Thread: [OLD] LogicMachine firmware 2021.12 (/showthread.php?tid=3755)
Pages: 1 2 3
RE: [RELEASE] LogicMachine firmware 2021.12 - Boolkinator - 14.12.2022
Is there support for DALI 2?
RE: [RELEASE] LogicMachine firmware 2021.12 - admin - 14.12.2022
CANx-DALI has support for parsing DALI2 telegrams: https://openrb.com/docs/canxdali-dali2.htm
There are currently no plans to add DALI2 support to non-CANx interfaces (internal and RS485).
Can I assign addresses and control the brightness of a lamps that has DALI2 with DW1?
What is the lamp make/model?
Centrsvet INF LINE 800 1630 WD DALI 2
Centrsvet INF TURN LINE 200 0530 WD DALI 2
Most DALI2 ballasts are backward-compatible with DALI1. Ask the ballast manufacturer for confirmation that it will work.
RE: [RELEASE] LogicMachine firmware 2021.12 - spyder - 11.01.2023
(14.12.2022, 12:20)Boolkinator Wrote: Is there support for DALI 2?
I have the same issue trying to use Dali for the first time on the Dali built-in master. My luminaire only has Dali 2: https://www.datocms-assets.com/47741/1640184659-datasheetdl32p-d2z0c1.pdf
Any chance to get Dali 2 also implemented on non-CANx?
Thanks,
Kristof
RE: [RELEASE] LogicMachine firmware 2021.12 - admin - 12.01.2023
Currently CANx-DALI does not have full DALI2 support. No decision has been made whether to support DALI2 on older devices.
RE: [RELEASE] LogicMachine firmware 2021.12 - spyder - 16.01.2023
Hi all,
It was due to a bad power supply that I did not manage to get Dali working.
Dali 2 is fully supported on older LogicMachine devices by sending raw commands on the bus. I was able to set the color temperature of a Dali Device Type (DT) 8.
Thank you for the wonderful products you build, it was a delight to work with the Dali internal gateway as defined in https://openrb.com/docs/dali.htm
RE: [RELEASE] LogicMachine firmware 2021.12 - aal - 04.02.2023
Which firmware is the correct one for this device?
log(io.readfile('/proc/device-tree/model')): i.MX28 LM2 Re:actor
My current firmware version is 20170620 (old). Can I upgrade directly to 2021.12 or should I first upgrade to mid versions?
Btw, thanks for continued support of older devices Smile
RE: [RELEASE] LogicMachine firmware 2021.12 - admin - 06.02.2023
Use this firmware (LM Reactor V1): https://dl.openrb.com/lm-21-mxs/reactor-20211215.img
