Bacnet - Script error - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Bacnet - Script error (/showthread.php?tid=3757) |
Bacnet - Script error - Alexander - 18.12.2021 Hi, I am getting an error when trying to run a script for changing the set. temp. See uploaded image. I want to change the set. temp. But this code doesn't work. Any suggestions? RE: Bacnet - Script error - Erwin van der Zwart - 19.12.2021 Use the command like this: bacnet.write(2, 'analog input', 126, value, 13) RE: Bacnet - Script error - Alexander - 20.12.2021 (19.12.2021, 10:50)Erwin van der Zwart Wrote: Use the command like this: Yes, that was the case. Thank you Erwin. |
