SpaceLYnk FW 2.7.0, problems with Touch 3 - Printable Version
+--- Thread: SpaceLYnk FW 2.7.0, problems with Touch 3 (/showthread.php?tid=3759)
SpaceLYnk FW 2.7.0, problems with Touch 3 - electric24 - 19.12.2021
Hi. After upgrading the FW on my SpaceLYnk (HW1) to 2.7.0 yesterday Touch 3 does not work any more.
Getting the following message: "Error in /www/apps/data/touch/lua/lib.lua at line 321: bad argument #4 to 'write' (string expected, got nil)".
Also in the "app-store" there are a an update for Touch 3, but when trying to install get a new error message "action failed, please try again later".
Does anyone else have the same problem, or does anyone have a suggestion for a solution?
RE: SpaceLYnk FW 2.7.0, problems with Touch 3 - Daniel - 20.12.2021
Check this
https://forum.logicmachine.net/showthread.php?tid=3752&pid=24228#pid24228
RE: SpaceLYnk FW 2.7.0, problems with Touch 3 - electric24 - 20.12.2021
I'm afraid that did not solve my problem. I have opened up so all user accounts have all access, and did a restart, but the problem is the same.
Cant acces either Touch or Touch Config.
Main thing there was enabled password for visu and apps.
Well, i dont have any passwords for for either visu or apps
RE: SpaceLYnk FW 2.7.0, problems with Touch 3 - Daniel - 21.12.2021
And this is the problem, you should have this enabled.
RE: SpaceLYnk FW 2.7.0, problems with Touch 3 - electric24 - 23.12.2021
Hi. I've added a password to all accounts (and did a reboot), but the fault is still present.
Do you have any other ideas for the fault?
RE: SpaceLYnk FW 2.7.0, problems with Touch 3 - Daniel - 23.12.2021
No, just passing what people suggested in the other post. Touch is SE responsibility.
RE: SpaceLYnk FW 2.7.0, problems with Touch 3 - Erwin van der Zwart - 23.12.2021
I assume the users already existed, can you try to add a new user and see if that one works?
RE: SpaceLYnk FW 2.7.0, problems with Touch 3 - electric24 - 26.12.2021
I've deleted all acounts and created one new one. Still get the same message.
RE: SpaceLYnk FW 2.7.0, problems with Touch 3 - admin - 27.12.2021
Check that your user access settings are the same as in this post: https://forum.logicmachine.net/showthread.php?tid=3752&pid=24228#pid24228
RE: SpaceLYnk FW 2.7.0, problems with Touch 3 - electric24 - 30.12.2021
I've think the access level is the same, but looks like the HMI is a bit different on my SL.
Also uninstalled the apps sugested furter down the same thread. Still no axcess.
Been thinking of uninstalling and reinstalling Touch 3. Do i have to set it up from scratch?
RE: SpaceLYnk FW 2.7.0, problems with Touch 3 - Daniel - 30.12.2021
User access settings are here
(30.12.2021, 14:54)Daniel Wrote: User access settings are here
Ah, THANK YOU.  Now it's working fine.
Also can get the app to be updated.
Thanks for ur assistance.
